Just upgraded my quad to 2.0.51 from 2.0.40 (been out of it for a while!). Doing it all through CLI as I can't get the new Mission Planner working in virtualbox.
Anyway when I reboot it after loading the code, in the CLI I get "Firmware change: erasing EEPROM" and then "Erasing log...". How long is this supposed to take? I've let it sit there for at least 10 minutes and it doesn't seem to get past this stage.
Tags: erasing, log
i have the same problem here.
i downgraded firmware do 2.0.50
well ...i recovered my ardupilot 2.0.52;
go to CLI setup
setup the radio
exit
after this your board will work normal.
Thanks for the response, glad it's not just me! Will try this tonight.
I am having the same issue with 2.0.53 hangs on erase logs.
Just installed 2.0.54 and it worked. Problem solved for me.
