IRIS HELP.... LOITER DRIFTING!!!
I consider myself an expert. Able to troubleshoot my issues but I'm very humble in the fact that I can learn something everyday. . I have green gps lock and I can only arm in stabilize and when I switched to loiter it drifts. .. Please help.
  • Well it was drifting before I touched anything... I'll put trim back to zero
  • You shouldn't be trimming anything while in normal daily flight.  You trim it for your designed and built weight and balance once using the SAVE TRIM function.  You must do this with no wind for obvious reasons.  Once you do that once, the trim is saved in the flight controller and your transmitter should be at zero trim.
    You definitely do not ever want to be using transmitter trim while in loiter.  Bad bad bad.  Remember, zero pitch, zero roll, zero yaw, and zero (mid) throttle in loiter mode is telling it to hold still.  If you add transmitter trim, you are no longer at zero, and therefore are commanding it to MOVE, not hold still.  Likewise, having any transmitter trim in stabilize mode will also be commanding it to pitch/roll/yaw.  With the controls at zero, the flight controller will level itself.  If you start adding trim, you are again commanding it to MOVE and it will never do what you want.
    Hence why you MUST use the SAVE TRIM function noted above to trim it out once and be done with it.  You can not have trim set on your transmitter.  Nothing will work properly if you do that.
    Also, absolutely no tuning, trimming, or balancing will work if your vibration is too much.  You need to address your vibration before you ever leave the ground or nothing will work right. http://copter.ardupilot.com/wiki/ac_measuringvibration/
    I would think since it is an Iris, vibration is already taken care of though.
  • Btw chris anyway I can buy the the IRIS gimbal mount.. I created a ticket for the loiter function not holding altitude and I broke legs? Props, and the gimble mount. .. I need the iris gimbal mount
