Hi Folks,
I have been working on viewing the data returned by the ardupilot.
I use the APM terminal to view the data returned through the serial port
however there is an issue. I get an error mesage (error reading com port) after some data
about free memory and initialization, and ardupilot starts returning some gibberish.
I have tried uploading the latest code through APM again with the correct baudrate but same result.
Any ideas?
Tags: ardupilot, com, error, garbage, gibberish, port, reading, telemetry
It's MAVLink binary, not ASCII. You can't read it the terminal.
Permalink Reply by Murat Tunca Aygun on January 18, 2012 at 10:11pm Thanks for replying Chris.
I need to be able get some sensory data from the system such as
GPS, IMU, etc. to display on a ground station software. Do you know how
can I see the data returned and /or parse it?
You need to write a MAVLink parser.
Permalink Reply by Murat Tunca Aygun on January 18, 2012 at 10:18pm Thank you Chris, I appreciate your help.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
139 members
312 members
678 members
117 members
Powered by
