Hi all,
I recently purchased an X8+ and today I had an issue with several (2-3) of the motors not spinning. I did the usual disconnects/reconnects and was able to run a couple of flights (one manual one autonomous) but the problem persisted until finally I couldn't fly it anymore.
This seems to be a problem with the ESC and the one big difference with the this flight and all previous ones I have done is that I was using a new battery this time. But it is a very good one that is commonly used on the X8 (specifically this Maxamps battery. It's an 11,000mAh, 4c battery so very similar in specs to the Turnigy one that comes with the copter. Plus this is only my 4th flight with the copter. Why would the ESC get uncalibrated so quickly? Is there any way to actually check the ESC calibration?
Any help would be appreciated.
have u tried this: read it carefully, as it requires *two* reboots and a special LED sequence to be present..... http://copter.ardupilot.com/wiki/initial-setup/esc-motor/#all_at_on...
Thanks I did that. But I am still not sure that is/was the issue. I checked the logs in Mission Planner and noticed nothing unusual. Guess I will find out if this did the trick when I fly it tomorrow!
