Joystick support
I have been trying without success to get the joystick option to work in Mission Planner.   I have tried connecting first and not connecting.  Nothing works. The program recognizes the joysticks, but does not save the settings.  Whenever I quit MP and restart it, the settings are gone.
If anyone knows how I can get joysticks to work, I would like to know.
  • Charles,  I need to implement your automatic failover between 4G and 915Mhz. Is your small pcb board you previously described available for this?
  • Not a lot.  I have been chasing so many other things.   like automatic failover between 4G and 915Mhz which I just got working.
  • Charles have you made any progress on this?
  • I finally did get joysticks to work.  But it appears that it is impossible to arm the craft by using min throttle + right yaw.  Is that the case?  Or is it just my setup?
