Kml log construction under APM planner broken
Hi all,
today i had my first really successful flight with the APM under Auto mode, and it worked pretty great!
I used APM 2.10 (as the logging function works correctly there), when i tried to view the recorded logs with Google Earth, the following track was recorded:
3690873228?profile=originalI also reconstructed an earlier Flight (from which i have a correct kml file), and this one too was broken.
Attached is a log file, with 2 kml files (one reconstructed with the up-to-date APM planner version (broken) and one with an earlier version (works)).
Okay, i hope this helps, you got me scared though for a moment, because i thought my gps was broken for a moment ;).
Hope you can fix this bug soon!!!
Thank you a lot
phil
08-06-11 01-54 10.log
08-06-11 01-54 10.kmz
08-06-11 01-54 10 (2).kmz
  • Hi,
    yes, it works brilliantly after changing the regional settings and restarting!
    Thanks a lot
    phil
    Hi ive found the problem,  to get it working change your regional settings decimal from a , to a . and the log will generate properly. i will fix in the planner in the mean time.
