Tags:
Permalink Reply by John Dell on December 2, 2012 at 5:43am For clarification, after you level your quad the pitch and roll show level....and then they become offset by 15 degrees while left on its own or do you need to do something to get it to show out of level? Does this happen gradually or instantly? Does it ever go back to level or just stay wrong?
Permalink Reply by Austin Suhler on December 2, 2012 at 6:46am I set the quad down on the floor, run level from the mission planner, wait for it to finish, everything shows perfectly level, so I arm, then take off. I get about 4-5 seconds of perfectly stabilized flight, until it starts slowly pitching back and to the right. Correcting for this only adds to the problem, until I'm using almost full correction on the sticks. When I land, it shows the offset. It does re-level by itself once I set it down, more of a it gradual and slow return to level over 4-5 seconds. The HUD just kind of slowly returns to level, like with pre-programmed precision, no snapping, just a perfectly smooth return to level. I can also get this effect just by manually tilting the quad and holding it there for about 8-10 seconds, and again, the instant I set it back down, it's 15 degrees off forward and left, and starts to return back to level over 4-5 seconds again.
Permalink Reply by Christopher Cooper on December 2, 2012 at 3:18pm Just a thought, do you have automatic trim enabled and assigned to channel 7?
The way I see it, if this were the case and channel 7 was always "high" this could lead to what you've described.
See here for auto trim:
Permalink Reply by Austin Suhler on December 2, 2012 at 8:55pm Checked it, and just for good measure, set up channel 7 as auto-trim, and made sure it was off.... no joy, same problem exists.
Permalink Reply by Austin Suhler on December 2, 2012 at 9:44pm I have a log file showing exactly what happens.... and it has serious repercussions on flight characteristics. Watch the HUD and you'll instantly see. I tilted in a few different directions, held it there, then returned to the exact level platform it started on.
Permalink Reply by Lloyd Breckenridge on December 3, 2012 at 6:54am Try loading the latest arduplane code into your APM and compare the difference in the HUD
Also check the box for tuning on the map window.
I find there is quite a bit of difference in how long it takes the HUD to return to level between the arducopter code and the arduplane code.
Permalink Reply by Austin Suhler on December 3, 2012 at 7:55am I will try that as soon as I get back form class, thanks! I have a plane I'm going to be putting another control board in anyway, and I should take a look at the firmware :) The problem is, though, the flight characteristics are exactly following what the hud shows..... I take of stable, the quadcopter adaptively changes its level, and starts flying specifically back and to the right, but upon setting it down and taking off again, it is perfectly level and stable for 4-5 seconds, then the process repeats all over again. I'll put up a log of the flight, and a log of the arduplane firmware when I get back from class.
Permalink Reply by Austin Suhler on December 3, 2012 at 10:51am Here are the logs for a testflight I just did with the quad, showing the disorientation in the HUD. The few seconds before I disarm, I've just landed, and the instant I disarm, it re-levels. The plane will be up in a minute.
Permalink Reply by Austin Suhler on December 3, 2012 at 11:13am Might help to upload the logs.....
The first file is the quadcopter flight, the second one is after loading arduplane on it....I find it interesting how the heading seems to be moving, even though it isn't, the quad is still, just tilted at an angle...
Permalink Reply by Austin Suhler on December 4, 2012 at 10:48am just wanted to bump and see if anyone's had a chance to take a look yet, thanks!
Permalink Reply by Josh Potter on December 4, 2012 at 12:07pm Also, in your parameters, your channel CH7_OPT is set to 5. The default is 7, I don't know what having that set to 5 does, but it sounds more and more like auto trim.
I would also advise with doing another erase on the APM, uploading fresh firmware, and do the very basic adjustments of rate p etc and then testing.
Permalink Reply by Austin Suhler on December 4, 2012 at 12:10pm Do you have a particular firmware version I should try? It's a 1.4 board, so not sure on 2.8.1 yet.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.182 members
15 members
50 members
247 members
106 members
Powered by
