Log & Debug info
Hello,
Last time I flew I noticed the PPM led stoped blinking 1 second. so I detected that the connector was faulty.
In the log I can See the GPS fix so tere are several things that I would like to be able to check in the log:
  • PPM signal "quality" or "availability"
  • CPU load
  • Channel values
I could not find the logs to be activated to see those info.
I noticed that the baro read both Pressure and temperature to compute Altitude.
O think logging Temperature might be also a good debugging feature to identifyrelated sonar problem for exemple...
  • Any Ideas ?
