Log File issue with 2.12
Hello Everyone, i just experienced a strange logfile issue. I uploaded recently APM 2.12 onto my APM. Flying worked just perfectly (FBW, auto etc.). However at home i tried to readout the logfile, and despite the fact that it should have recorded several logfiles (i reseted a couple of times to get some good logfiles which show some clear flightpaths), there was only on stored and that one was broken (I attachted this one).
When i uploaded version 2.1 the logfile recording just worked fine. Did someone encounter the same problem? Can someone help me with this?
I would very much appreciate these logfiles, what are the advantages of 2.12 over 2.1?
Thanks a lot for your help
phil
06-06-11 02-38 1.log
    Yes, this error is mentioned in Issue 352
    There is also suggestion for correction. But you need source code and Arduino compiler. You must correct one line in Log tab.
  • Same here - my logs worked on my arducopter mega, but on my ardupilot mega funjet, I also get bad log number
    Log] dump
    bad log number
    logs enabled: ATTITUDE_MED GPS PM MODE CMD
    1 logs available for download
    Log number 1, start page 2, end page 958
    Alpage 2, end page 958
