Log File Naming
I'm sure I'm not the only one to ask this question, but is there a parameter you can set in APM Plane or APM Copter that will allow you to insert pretext into the log file names? If you are flying a number of UAVs, regardless of the hand notes I make, it's hard to determine which log file goes with which flight. It would be great if you could put a parameter into the autopilot firmware so that the log files are named with the UAV's serial number or nickname.
