Hi all,
I'm sure I missed something basic but: my copter is not saving any flight logs.  Going into the CLI in the logs function, I see that GPS PM CTUN NTUN CMD are set to log enabled, but every time I use the Log Download function it tells me "No logs."
What am I missing?
Could be a corrupted log file. You shoud try to delete all logs.
Did you had a crash, or did you power off the board before disarming motors ? This could have produced a log file corruption.
I did had this problem at least two times. Perhaps you should open an issue in the issue tracker, so that eventually an automatic file recovery procedure would be implemented later.
I have run a number of "delete all logs" operations and the motors are always disarmed before unplugging the battery (because I am terrified of the props) so I don;t think those are it...
Then i think you should report the problem in the issue tracker. I did have the same problem but was able to recover.
