  • Given that you haven't fixed on a final setup (or at least it appears you have some uncertainty remaining to resolve) I would suggest you try one of the online calculators, such as XCalc. If you cannot solve your problem using that, check back here and I can try to help.
  • It will depend on the load applied to the motor and the RPM you want to run it at... what prop is it turning...
  • As if there is no one knows how to do this on this site...
