Hi, I have the telemetry port connected to 2 x XRF modules. The whole costs 32 € incl XBBO and runs on 314 MHz to 915 MHz (software) baudrate at 57600th Works great. Dear greetings from Germany :-)
Link:
Www.shop.ciseco.co.uk/xrf-wireless-rf-radio-uart-rs232-serial-data-...
Tags: telemetrie, xbee, xrf, zigbee
Permalink Reply by Vincent Mees on January 26, 2012 at 2:47pm Nice find.
And these can be used with the same interface boards as the Xbee?
Permalink Reply by Karsten on January 26, 2012 at 3:23pm
Permalink Reply by Alex on January 26, 2012 at 2:50pm What frequency do you use? Because i've saw that you can change between several frequencies. Can you tell me what exactly do you bought and in which quantity ? Thank you.
Hi Karsten,
What range have you been getting with these units, and on which MHz are you running them at?
Do they have the duty cycle on the 868 MHz setting which kills the Xbee 868's for use here in the EU?
I will stay with the 2.4 GHz Telemetry kits which are known to work well and have full EU certification, I can't see how these will work with the APM 2 I guess we will see what the other people say about them.
Regards
Martin.
Permalink Reply by Karsten on January 26, 2012 at 3:20pm
Permalink Reply by Javier Robaina on January 26, 2012 at 3:04pm been any evidence of achievement of these modules?
Powers that are sold?
Good news, greetings.
Permalink Reply by Karsten on January 26, 2012 at 3:09pm
Hi Karsten,
So are these units legal / illegal for use in the UK & EU then? The reason I ask is, that I think they offer oustanding value for the features and range, but after spending weeks looking into the 868 band and spending a good sum of money, they were useless as there is a requirement for the "duty cycle" :(, I have another 868 option sitting here on my desk right now, its more expensive however they make these units look like they are very short on range, but are illegal to operate here in the EU, and that's why they are not being sold for telemetry use right now.
So do these units have the "duty cycle"?
Regards
Martin
Permalink Reply by Karsten on January 26, 2012 at 3:52pm
Permalink Reply by Emiliano Fortunati on February 6, 2012 at 4:21pm Hi Karsten,
I'm trying two XRF modules,
When I try to connect APM it start to get param list but do not complete the operation.
In the debug windows I've a lot of crc errors.
I've, like you suggested, setup the packet size to 140.
Do I've to setup any other parameter in XCM? Sleep, Flow Control, Radio data rate?
I'm using a standard 57.6 firmware setting, and with the original Xbee module it work fine.
THANKS a lot!
Permalink Reply by Emiliano Fortunati on April 5, 2012 at 12:53am Hi Jason, I've a similar situation.
After many tests, I've found a good configuration with low packet loss.
The main problem is that these devices work in a different mode from Xbee and I've found the problem in the internal conversion from "cable to RF".
I've abtained a lot of info from ciseco support forum, they has sent to me a new firmware for a better conversion.
But for me is too unstable so I've abandoned this produtc.
BYE!
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
1355 members
24 members
207 members
58 members
Powered by
