Mabotic LV-MaxSonar-EZ
I was just wondering if there was anything special I need to do to get this sonar working with the APM code, right now its only showing 20cm. Also the pin its attached to might be broken because if I give it anything voltage wise it doesent change values. What is the actual pin the sonar signal wire is attached to?
  • Well I know that it was working before last week, I lost a couple props and have not plugged in the battery since so I dont know how that would have happened. Maybe it has something to do with this
    http://diydrones.com/forum/topics/imu-board-or-magnetometer-broken
  • Such being the case the input channel to the IMU is likely shorted. Your sensor is good.
    In the past I have seen a input to a Industrial controller specifically Allen Bradley show a discrete LED.
    However while communicating to the processor it did not show while online.
    The Input channel was at fault even though the LED displayed.
  • 3692253538?profile=originalLook on your oil pan (blue IMU board) and locate the pitot tube pins; says "pitot", opposite end of the relay switch. On the bottom side of the board you will see gnd, +5V, and IN. The signal wire for the sonar should be connected to IN. As for the sonar itself, I have the signal wire connected to the AN output.
