Tags:
yes, it's directly near the power line of one ESC
the powerline causes a magnetical field which affects the magneto readings
solution: move the magneto somewhere else, like on top of APM
Permalink Reply by geir on January 18, 2011 at 1:25pm Did you calibrate the magnetometer in the CLI, as instructed in the manual?
Permalink Reply by geir on January 18, 2011 at 2:54pm
Permalink Reply by geir on January 18, 2011 at 3:13pm How much does the heading change when you change the roll or pitch by say 45 degrees? if it's 7~10 degrees or so that's normal. It's a bit inevitable that it changes that much and it's good enough to do your heading hold and GPS pos hold.
Also can you paste the offsets you see from the CLI Menu here? I strongly suspect that you didn't quite do the calibration correctly so your offsets are off.
The kinds of mag problems we see when it's really broken are:
1. it returns all zeros
2. it returns very shakey values (sometimes after a delay)
when it's the heading changing when you roll or pitch it's always the orientation or offsets.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.314 members
4 members
1292 members
684 members
110 members
Powered by
