Tags:
Permalink Reply by Mathias on April 28, 2010 at 6:28pm
Permalink Reply by Mathias on April 29, 2010 at 9:23am
Permalink Reply by Navigator on January 24, 2012 at 4:42pm Hi Mathias,
I am also using DCM to get correct orientation in a smartphone application, Can you plz tell me how I can get the orientataion (three angles , yaw pitch roll) directly from DCM matrix, as if I calculate orientation using Euler angles (using atan2 function), I get gimbal lock error, I have gone through DCmdraft2.pdf but i am not clear how to resolve it.
regards
Navigator
Permalink Reply by Navigator on January 24, 2012 at 7:13pm hi, what i understand from DCMdraft2 is that to get orientation vector direct from DCM matrix is to use rmat[6] for pitch(dot product of roll axis(first column) with ground vertical[0 0 1]), rmat[7] for roll(dot product of pitch axis with ground vertical) and rmat[4] for yaw angle (dot product of body Y axis with earth Y axis), is it right? Anybody plz can verify if i am wrong?
regards
Navigator
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.58 members
24 members
1355 members
88 members
207 members
Powered by
