Hi I have an ArduCopter and I want to modify it's motor and battery to make it:
Control payload of max. 10kg
or/and
Fly at least 3 hours
Please advice how should I calculate it. Is there any formula for calculation of needed battery and propeller or motor?
I'm not an expert in electronics, I just have good skill in Unix operating system and C programming. So please share with me your expert ideas. I want to know what Kv motor I'll need (4x of it) and what battery would be required (like I got 5200 mA).
Looking to read your expert comments/ideas...
Tags: ArduCopter, Fly, HeavyLoad, Modify, More, Time
Adam,
You indicated the "Nemesis" has a maximum lift of 10 kg and with the supplied batteries can last 45 minutes with the camera you using.
Questions:
1. What's the flying weight of the octo with everything (i.e., electronics, frame, batteries, etc) except camera?
2. What's the weight of the camera you were using in the sentient video?
3. Maximum amount of payload will be the difference of 10kg and the answer to the 1st question, right?
Thanks.
Roger,
I am hoping to do a max payload test today in a gymnasium with no wind so I can get more accurate figures for everybody. I am using a GoPro camera which is very light to get longer flight times.
1. Flying weight is 15.6lbs / 7.076kg. That is including everything but the camera (APM, telemetry, wireless video tx, 2 x 7800mah batteries, props, landing gear, etc)
2. I use one of two cameras when filming. Either I use the GoPro (.37lbs / .167kg) or my Canon T3i (1.73lbs / .783kg)
3. I will post an exact figure and video to this forum when I run the test today using 3s batteries. I should also note that it will also depend on the batteries you run. If you stick with 3s you will have great motor efficiency but reduced payload. 4s batteries will provide more lift but at a reduced motor efficiency. The theoretical static thrust output of the Nemesis running 3s batteries is 25.5lbs / 11.6kg with 82% efficiency. The theoretical static thrust output of the Nemesis running 4s batteries is 43.12lbs / 19.6kg with 80% efficiency.
As I stated in the previous comment... Is the Nemesis capable of lifting that weight? Yes... but it is not a practical scenario because the flight time would be quite short.
Adam,
Will be looking forward to the results of your test.
Meanwhile, Using a gopro or canon, the overall flying weight considering everything are 7.243 and 7.859 kgs. You indicated lifting 7.243 kg (go-pro configuration) you got 45 minutes flying time. With the canon configuration, what's your observed flying time?
Thanks.
Roger,
Unfortunately I did not have time for the payload test this weekend. I was busy preparing for some volunteer work for a non-profit search and rescue organization. Sentient Drone is going to volunteer the use of a Nemesis for searches using thermal imaging from above. I have one last prep flight before a mock search and rescue next weekend. I will try to get a payload test for you at that time using the 3s batteries, but I imagine it will be pretty close to the theoretical values.
Thanks,
Adam
