Is there any way to manually set the level of the plane in the air?  I have a large tail dragger that I can get the apm close to level for takeoff, but would like to fine tune it in flight.  I use the manual level on my easy star and it works great, but it is hard to do with bigger planes.
I think this function should become a basic part of APM. It's very hard to place a plane/copter really level enough to calibrate it. Although we can trim it using the TX a little bit but this is not a good solution......
My quadcopter always drift to one side a little bit no matter how hard I tried to calibrate it using papers to adjust the height of the legs etc, just can't make it level enough, once it drift to the left and I add paper to compensate it, then it drift to the right/front/back......
