So as of yesterday I am unable to make a MAVLINK connection through my telemetry gear, but only on my laptop. When I hit connect (yes, port and baud rate are right, CLI switch is in the flight position) the connection window immediately disappears without counting down a timeout or displaying the "get parameters" screen. About 15-30 seconds later I get the following error message:
System.ArguementException: offset and length were out of bounds for the array or count is greater than the number of elements from index to the end of the source collection.
at ArdupilotMega.MAVLink.Open(Boolean getparams)
as ArduPilotMega.MainV2.MenuConnect_Click(Object sender, EventArgs e)
This occurs only on my laptop. With the telemetry gear plugged into my desktop PC it works fine. The laptop also worked fine previously, and I have made no changes to its hardware since then - I assume it's something to do with the latest planner but not sure.
I have tried reinstalling both the current (.14) and beta (.17) FTDI drivers from the link provided in the wiki.
I have updated MIssionPlanner to the latest and have tried to connect to both ArduPlane and ArduCopter, both with the most recent firmware.
Any thoughts? If only I could bring my desktop to the flying field... :)
Tags:
Please revert to 1.0.86 while we sort this issue out.
This is now fixed.
(We'd pushed an MP update for MAVLink 1.0 before the accompanying ArduPlane and ArduCopter updates. Just a sync issue.)
Hi Chris, i have a Atmega 1280 board, and firmware v2.24 uploading. I have test all the Mission planners from
1.0.86 to 1.0.95 in both my lap and desktop computers ( Vista and win7). The connection with USB is ok , but in wirelless ,i have the same problem :
The wirelless is working with HK GCS
Any ideas....?
Thank you
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.684 members
4 members
1291 members
110 members
184 members
Powered by
