Maximum current for 3DR power module
Hello,
I am building a hex with 14" props for lifting a mid sized camera. I am pretty set on running a 4S setup, as I can share batteries with my other quad.
I calculate in hover I should be drawing around 30 amps. That is not a problem, but RC-calc is showing a max current of over 120 amps at full throttle. Granted, full throttle climbouts are a rare thing and I don't know that it will actually pull this, but that has me concerned a bit.
The 3DR module only lists its 'maximum  sensing current'. For APM it is 90 amps and Pixhawk it is 60 amps.
http://store.3drobotics.com/products/apm-power-module-with-xt60-connectors
Can the module pass my max current without danger? Blowing the shunt and having no power would be a bummer.
Any insight is greatly appreciated!
