Measure volt only
I want to measure volt only because if using Attopilot or power module.You have to let all
the power go throw a shunt resistor if it break(no connection) you have no power and the copter
goes down.... Or have i miss understand the function?Any way if I use Pixhawk and connect
two becs to it and measure only one bec using attopilot.Can that work?(see drawing)
As I understand you must have something that draw current throw the attopilot(powermodule)
Otherwise  current or voltage measurement will not work, or?power%20pixhawk.jpg
  • The resistor won't break, it's able to dissipate enough power even if you drew seriously to much current.
    If you are seriously afraid of such simple component failing, you can parallel two, and calibrate, or parallel two of twice the resistance.
    • Ok that was a nice idea! But what do you think about connect everything as in the drawing?
      I will use two bec to pixhawk.
      • seems good :)
