All:
This issue seems to be prevalent across the forum so I ponder if a FAQ or some steps to sort through this issue. I bought a new MediaTek GPS from the DIYDRONES store. My thought was this thing should be ready to go and plug in. Anything that ships would have whatever latest firmware needed especially for a part such as this.
Anyway, whether this is firmware related or not I do not know as I have not fully exhausted all analysis. I wanted to post a fresh thread that made it clear what the symptoms were so that others could lend advice, solution, or plausible explanation for others who are having this issue as well.
The issue is as follows:
I have the AdruPilot Mega board and the ArduPioletMega IMU Rev-H. The boards are mated as per all instructions and the MTEK GPS connected. I power up via USB, load the software and check things out in CLI mode. Likewise, have tested the other sensors with the Calibration tool.
What I noticed is that the GPS blue LED locks. However, the RED LED (C) never flickers, never locks. I also noticed that GPS data when I run some other coded test I snubbed in report all zeros (0).
Can someone tell me what is the logical next step to get this issue resolved or do I just send the GPS back and request a new one. I assume it is working and that the issue is in the communications between the GPS and ArduPilot Mega board.
Is there new firmware that for some reason is not on the GPS boards being shipped from DIYDRONES?
Thanks in advance for any input and steps to resolve. I am certain others can benefit from a definitive solution as well.
GH
Tags:
Gary, as we've discussed here before there was a glitch in our shipping schedule last month where we were sending out MediaTek modules with 1.6 firmware before the software supports it. We've apologized and explained this and taken corrective action. We have now released APM software that supports it and the ArduPirates are adapting ArduCopter code to do so as well.
Assuming you have a MediaTek with the 1.6 firmware, which is why your ArduCopter code is not showing lock, you have three options:
Permalink Reply by Ed Windham on January 14, 2011 at 5:31pm The MTK that came with my (first batch) FahPah Arducopter seemed to match the RC2 code.
The Red LED does NOT come on until you first switch into GPS Hold mode. This was a discussed bug, it seems.
Permalink Reply by Ed Windham on January 14, 2011 at 10:41pm
Permalink Reply by Ed Windham on January 15, 2011 at 12:03am Watch the LEDs.. the yellow LED should toggle with GPS Hold.
After you switch into GPS Hold (disarmed), then the RED Led should track the blue one.
Permalink Reply by Gary H on January 14, 2011 at 10:08pm
Permalink Reply by Gary H on January 15, 2011 at 4:22pm Chris
I loaded the new APM code selected the corresponding values as needed in the APM_Config.h and tested the GPS. So all is working just fine. I will await the new ArduCopter code once it is available.
GH
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.86 members
51 members
671 members
1280 members
8 members
Powered by
