Hi. I am new to minimosd but have tried to research my question on forum but no luck so far. I would like to know how to get minimosd to show the battery "mah used" value and associated icon instead of the "%" value and lightning bolt icon. I have read where this is possible to select using config tool, but have not found a way to do it during configuration of the panels. I am also confused as to whether this can or cannot be done with "standard" minimosd or does it require "minimosd-extra". Thx
Regards
Mike
Get the newest MinimOSD-Extra firmware.
Hi...and thx for the reply.  I went to the minimosd-extra site and downloaded the 2.2 CT and hex files and installed.  When I ran the CT it still only shows "Battery percent" as a displayable field (no option for "mah used")....AND....I noticed that even though I was running the 2.2 "extra" CT app file (as shown in the Windows install folder), the title at top of CT panel did NOT say anything about "minimosd extra".....so not sure if this is the correct executable or not.
Any suggestions how to verify the correct CT is running?...or that I have the correct version which supports "mah used" field?
Thx...
Regards
Mike
2.2 is old, find the latest here: https://code.google.com/p/minimosd-extra/downloads/list
You should see the option on the 1st tab:
(Sorry for the crappy photo)
Perfect!!!  Got it working correctly.  Thx for your assistance.
