MinimOSD battery voltage error
Is there a parameter setting in APM 3.2 that alters how the battery voltage is displayed in telemetry?
Mine's out by at least a volt. Perhaps some sort of calibration necessary? I'm using APM 2.6 and a power module with the Minim powered by a seperate Ubec. Thanks...
  • Hi, its edit correction
    its Batt_Volt_Mult
    • Thanks Stuart. I'll try some other values. Best. DP
      • cool, you should be able to use the ratio of actual voltage and what you are reading to get you very close. If the reading is low I think the ratio should be above 1.....new Batt_Volt_Mult = actual/telem value x  old Batt_Volt_Mult I think :)....invert the ratio if I got the wrong way around.
