Hello , I have problems with minimosd information. When I turn on the Pixhawk the minimosd information appears on my screen Fatshark , but without information, all can see is number zero.
  I plugged the minimosd in Telemetry port 2 and Telemetry 915MHz on the telemetry port 1. Someone could explain why the OSD is failing to pass the information to the screen? The only information that is working are the flight modes " stabilize " , " loiter " , "GPS" , nothing more.
Hug.
  • Hi dude,
    Have you solved this issue?
    Because I've the same.
    Thanks in advance!
    • Hi, I solved my problem with this video, (see after 10:05 minutes of video):
      https://www.youtube.com/watch?v=z1xM_m-ur5c
      It's in portuguese language, but have video demonstration, very easy to understand or access this site:
      http://www.helicopeteros.blogspot.com.br/.
      Hug.
    • :I had these symptoms..
      In my case I had two issues.
      One, I had tx/rx swapped.  The pinout diagrams I found online were mislabeled, or maybe were labeled for the receiving device (even though the peripheral wasn't shown on the diagram).
      And, when the RX wire was connected to RX input, it still picked up the mavlink heartbeat, so the screen displayed, but with no info.
      And two, I'm using minimosd EXTRA, which has some settings for the sr0 and sr1 or sr2 settings.
      While connected via USB, it looks like you can change the sr0 settings, but they don't actually change.  When connected via telemetry, you cannot actually change the SR1 settings.  In both cases, it's because that is the active connection, and I guess it makes sense that you can't change settings on an active link.
      So, connect via usb and changed SR1, and connected via telemetry to change the SR0 settings, and they all saved.
      That was it in my case.
