MinimOSD No GPS
Hi Guys
I have my MinimOSD flashed to 2.0 firmware and it is working, I can see characters. (not so clearly but i've reflashed firmware+charset multiple times so suspect either VTX or cam or goggles here)
When I switch the flight mode, I can see the flight mode changing on my OSD.
However, none of the GPS related measurements are showing.
No lock, 0 sats, and lat/long both show 0.
(altitude, home dist/angle etc are all zero or not showing)
The 3d-fix light on the board is solid blue, if I plug the USB in, it shows 3d-fix and shows my location.
I do not have the TX wire (minimosd side) connected to the APM2 so I have manually set ST3_Extra1 to 5 for the mavlink data frequency. I am adding a 3dr telemetry kit as soon as it arrives so as per instructions I did not connect that wire.
As an aside, i've attached a photo of my OSD in case it helps (you can also see what I am describing as unclear characters)
What is wrong?
  • Okay, figured it out.
    The wiki says you only need to set sr3_extra_1 to be 5.
    You also need to set some of the other sr3_ (eg. sr3_position) or you don't get GPS data.
    This is in the wiki for the minimosd-extra but not for the arducam-osd
    Still unsure about my weird rendering of characters (note the small vertical spaces)
    Some of it is barely legible on the goggles, but I can for example read armed/disarmed pretty clearly.
    Just to reiterate, I've made sure I power the board correctly when flashing the OSD charset
