I've just given minimosd the firmware upgrade to support Mavlink 10, and now it will boot up but will never get past 'waiting for mavlink heartbeats'.
I'm running 2.6 on an APM1 2560 and have made sure that my board is using mavlink 10. Eg I am using APM planner 1.1.92 mav 10 and it connects fine. The minimosd is one of the earlier ones - version 0.1
I have been using this osd with mavlink 0.9 for the last few months with no problems. It is just since the firmware upgrade that it won't work.
I have tried putting the old mav 0.9 firmware back on the minimosd, and changing the APM board to disable mavlink 10 via arduino and reuploading, but even that doesn't work any more! It still gets stuck at 'waiting for mavlink heartbeats'
I've checked that the wires are connected correctly from the telemetry port on the APM, and that they aren't broken, and have also checked (and reflowed) the pins at both the APM end and minimosd end to make sure none of them were loose.
I don't have xbees either.
Help!
Tags:
Permalink Reply by Eric Tweet on June 16, 2012 at 8:49pm I'm in a similar boat. I don't have a cable to update the MinimOSD firmware, but I've upgraded to 2.6 on my APM (which is now MAV1.0). I haven't tried booting up with the OSD, but instead I'm looking for a way to revert to MAV 0.9 until I can get my hands on a cable.. Too bad there's not an option in Mission Planner to select which MAVLINK version to use..
Permalink Reply by Glenn M on June 17, 2012 at 2:14am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.11 members
182 members
184 members
1290 members
684 members
Powered by
