Mission Planner 1.3.16, Terminal getting garbage
Hello I recently update MP from 1.3.15 to this latest version and I notice that when I tried to access the CLI under "Terminal" tab, the screen is displaying garbage instead of readable words.The reason I'm in this tab is because I want to do log download and this screen too is displaying garbage.I suspect it is something to do with baud rate but I checked USB Console-115200 & Telemetry-57600.Please help.
    terminal is being removed, so it doesn't do anything any more
    • Thank you Michael
      I'm honored to have the man answered my queries. Pardon my ignorance, is there a web documentation on Mission Planner?
      Regards
      David
  • Same here, but I also wanted to use terminal to change the logging.
    Seems you can only do that through changing the log bit mask now in the full parameter list.
    There is a log download and graph facility in the Flight Data window.
    It uses Mavlink to download the logs. Very slow but it does it.
    • Thank you Mike.
      I wonder why this was changed, likely they ran out of memory.
