I've just updated to the latest mission planner (version 1.3.42) and i was surprised to discover that the there is no more access to the "Full Parameters List".
I was kind of used to this list and it appears that some of the parameters aren't accessible anymore (all the EK2 parameters for example).
Is there a way to make this list appear again ? Or is there a reason it was removed ?
I'll go back to the previous version in the meantime and hope you'll be able to provide some help.
Thanks a lot,
Best regards,
Thomas
open MP and without connecting go to config/tuning and check the layout/advanced from the dropdown and see if it now lets you get to the advanced areas such as full param list and tree view
Hi Craig,
Thanks a lot for your quick answer.
It solved my problem. I should have searched deeper into the problem...
Thanks again !
I tried opening MP v 1.3.43 without connecting then opening Config/Tuning but it only lists Planner on the left panel (no options for Advance Parameters).
Solved;
-I backdated MP to v 1.3.41 and now have access to the full parameter list.  #thanksdonald
It's there, I guess there is a new layout option:
...and it doesn't show immediately, so after changing to Advanced click on one of the other tabs and then back to Config/Tuning for the full list to show.
