Mission Planner hangs when writing parameters?
Guys,
I seem to have an issue with my APM 2.6 board. It seems I can no longer successfully write parameters from MP. I've tried multiple files without success, normally it gets to parameter 15 ish and then just stops.... Any ideas?
I'm not sure if it is related but my MinimOSD has also stopped receiving data and now just displays "no mav data". I've tried an erase and reflash, no difference (took forever because I couldn't write my old parameters back!).
Help?
  • Maybe a problem with the SD card?
    • APM 2.6 doesn't have an SD card... I should add, this is the same regardless of if I connect via USB or Telemetry....
