Mission Planner Joystick setup problem
I'm trying to get a USB joystick working with my Cheerson CX-20 quadcopter in Mission Planner,
I am able to configure the various axes under Joystick setup but they do not get saved.
I get an error about file access permissions to "Mission PlannerjoystickaxisArduCopter2.xml"
Has anyone else experienced this?
  • Very old post but I am curious. Could you fix it and get joystick working with the CX 20?
  • OK I found the problem... there seems to be a bug in Mission Planner
    The joystick setup file is supposed to be located here:
    C:\Program Files (x86)\Mission Planner\joystickaxisArduCopter2.xml
    But when trying to save the config, the app is trying to write to:
    C:\Program Files (x86)\Mission PlannerjoystickaxisArduCopter2.xml
    There is a missing "\" before joystickaxis....
    The workaround was to manually copy the XML file into the correct location and edit it with a text editor.
