I burned Arduplane 2.77 code into APM 2.6 board using Arduino IDE 1.0.3. then using the latest Mission Planner I tried to connect the board to the GCS. the error recieved is "No heartbeat packets received".
  • I tried with the newer versions of arduplane codes. received the same error.
  • I have tried changing the board. no effect.
  • checked the baudrate in the pc. all ok.
  • checked the config file. all ok there too.
please help with a solution ASAP.
