Mission Planner Not Displaying RC Responce
I am using a Pixhawk as an autopilot, and am using a FrSky Taranis Plus transmitter with a Delta 8 receiver.
I have inserted the connectors in the CPPM/1 slot and put a bridge between pins 3 and 4. I have connected it to the Pixhawk using the RC in slot, and have then bound the transmitter and reciever in D8 mode. This has resulted in the receiver LEDs showing a solid red light and a flashing green light, indicating it has bound. When I try to calibrate the radio on Mission Planner there are no green bars showing. These green bars are supposed to indicate the position of the controls on the transmitter.
I am not sure how to get this working so any help would be appreciated.
Things I have tried:
Re-installing Mission Planner.
Connecting the Pixhawk to my laptop using the telemetry set, and also with a cable.
With and without the bridge across pins 3 and 4.
  • Unlike the APM you connect a PPM input to the Pixhawk on the pins marked "RC". Left most. No jumpers needed.
    • I get it, you were talking about the receiver pins. You remove the jumpers after binding right?
