Just a quick question and something simple. How low can you go with the settings at the bottom of the flight planner, that are Loiter Radius and WP radius? I would like to crunch them down a little but what happens if you go to far?
Tags:
you could technicly do 1, but this is somewhat pointless, as gps accuracy is at best +- 10 m. you should set the loiter radus dependant on the plane, and wp radus dependant on your groundspeed and max bank angle. so you get nice curved turns between your 90 degree wp's
Permalink Reply by Bradley J Carr on April 27, 2012 at 5:31am I am flying a 3dr quad. I had to change the speed of flight because it took off yesterday and overshot the target by a long ways. Thanks for the answer I was just wondering if it had reached the radius of the way point if it would think that it was there and then continue on to the next way point. With the limited amount of space I had I was trying to get it as close as possible.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
1290 members
10 members
684 members
87 members
Powered by
