Guys:
Today when I started the mission planner I received a notice of an update.  I updated it, but how do we know what was updated?
Thanks!
Bret C
Mike:  Thank you for the note regarding the MP updates.  Along with this update, are there updates for the APM as well?
Thank you.
Bret C
Had anyone had any issues with 1.2.36?? I havn't done the update yet. Just trying to minimize any issues since I havnt. really got off the ground.... but very soon!!
Brian
Yes. I had. I reflashed my APM with ArduCopter 2.9.1 and it seems to not work at all. I connect over telemetry or USB, the HUD display shows me no changes. I used a serial client to check what's wrong. Basically the firmware does not send back the datastream. Also when I plug-in battery only one motor connected to output pin 1 does the usual sound. Other 3 motors keep beeping as if they are not getting any PWM input.
I believe that the problem is with the firmware that gets downloaded from the internet. My previously uploaded firmware using the non-updated Mission Planner (1.2.35) used to work really well. I think irrespective of the version of Mission Planner, the firmware downloaded from internet is always the latest one as long as your ArduCopter version remains same. Administrators kindly check issues with the latest precompiled hex file of Arducopter 2.9.1 that is being sent to the Mission Planner firmware requests.
Thanks !
BUG in Mission Planer 1.2.36
after press the Update Butten the following Error are in the Update Log and the Update Process is canceld
2013-03-27 12:59:02,130  INFO ArdupilotMega.MainV2 - OK (C:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\MainV2.cs:2520) [ProgressReporterDialogue Background thread] 2013-03-27 12:59:02,146 DEBUG ArdupilotMega.MainV2 - New file Check: 3322 vs -1 "79cf7309dd994a79f70f35b38a317096" vs  (C:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\MainV2.cs:2547) [ProgressReporterDialogue Background thread] 2013-03-27 12:59:02,161  INFO ArdupilotMega.MainV2 - NEW FILE Arduino MEGA 2560.inf (C:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\MainV2.cs:2555) [ProgressReporterDialogue Background thread] 2013-03-27 12:59:02,177 ERROR ArdupilotMega.MainV2 - Update Failed (C:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\MainV2.cs:2263) [ProgressReporterDialogue Background thread] System.ArgumentOutOfRangeException: Das angegebene Argument liegt außerhalb des gültigen Wertebereichs. Parametername: size    bei System.Net.GZipWrapperStream.Read(Byte[] buffer, Int32 offset, Int32 size)    bei ArdupilotMega.MainV2.updateCheck(ProgressReporterDialogue frmProgressReporter, String baseurl, String subdir) in C:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\MainV2.cs:Zeile 2614.    bei ArdupilotMega.MainV2.updateCheck(ProgressReporterDialogue frmProgressReporter, String baseurl, String subdir) in C:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\MainV2.cs:Zeile 2494.    bei ArdupilotMega.MainV2.updateCheckMain(ProgressReporterDialogue frmProgressReporter) in C:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\MainV2.cs:Zeile 2215. 2013-03-27 12:59:07,708  INFO ArdupilotMega.Controls.ProgressReporterDialogue - DoWork Done (C:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\Controls\ProgressReporterDialogue.cs:78) [ProgressReporterDialogue Background thread]
Yep get an error updating too
Yep, I get the same error
+1. I then downloaded .38 (.msi) from the site (http://code.google.com/p/ardupilot-mega/downloads/list) but when I start the MP it still says .36
Doing the download of the .msi fixed the problem.  Thanks
One more, i get the same error !!!
Desole que vous rencontrez des problemes Eric. Il est possible d'obtenir une plate-forme stable d'utiliser cet appareil comme beaucoup de gens l'ont montre. Rappelez-vous aussi que l'equipe de developpement ne travaillent pas tous a la meme chose, donc il n'est pas rare pour les fonctionnalites a developper dans des ordres differents.
Nous jouons avec quelque chose qui est "Bleeding Edge" et un peu de patience est necessaire, mais il ya d'autres options si vous souhaitez evaluer. OpenPilot par exemple?
Heureux de discuter avec vous via PM si vous le souhaitez.
David.
I just love the new look of the diydrones website....way to go Chris Anderson and the APM team......
