I have recently installed the 1.2.26 version of the mission planner and now my computer wont recognize when i plug in an arduino mega 2560 board (neither the arduino program or the mission planner). I am looking to find out if and when diydrones plans to fix this issue?
Tags:
Permalink Reply by Criterion-Industries on December 12, 2012 at 9:32am Did you solve your issue? I see you posted in the other thread about this.
http://diydrones.com/forum/topics/mp-1-2-25-on-xp-using-usb-driver-...
Yes-ish, I still cant delete the drivers that it wants to use but I was able to get it to allow me to update them to the correct drivers. The downside is for every arduino board I connect to program I have to manualy pick the correct driver.
hopefully with the new msi i just released this issue should be fixed.
Hello Michael,
how i can configure MissionPlanner to use 2 stop bits in my connection with the APM?
My XBees work well in 115Kb with 2 stop bits but with only 1 stop bit i have a lot of errors... So i must use 56Kb with 1 stop bit...
Thx for your help!
Best
Guillaume
I uninstalled the previous version and installed the newest one and still have the same issue of it trying to use a generic USB driver instead of the arduino one.
is this xp?
Yes, xp with the service pack 3.5.
Can you please test these drivers
I can manually chang the driver that it uses but I have to do it with every board I plug in.
Permalink Reply by Anderl on December 14, 2012 at 2:30am I needed also the "directx_Jun2010_redist.exe"
Anderl
Permalink Reply by Nenad V on December 16, 2012 at 5:36am I have installed the 1.2.27 version of the mission planner and my computer wont recognize when i plug in an arduino mega 2560 board,same problem as Levi Vilson.I try drivers Arduino Mega 2560.inf and arduino mega 2560 cat by Michael Oborne and again not recognize.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.183 members
1278 members
182 members
24 members
51 members
Powered by
