Mission Planner waypoints
Is it possible to make your mission from a computer at home and load it before you go fly.  I would like to do this but it wants the home position.  If I plan the whole thing out what will happen after it locks on a GPS signal in the field?
    Yes, that's fine.
    In the APM, "Home" position is normally set to the position you powered-on the airplane ( after GPS lock, of course).   In your case, the correct thing will happen so long as the pre-configured "Home" is actually your planned take-off point.
    Should you take-off from a different location, then your mission will still be take-off point -> 1 -> 2 -> take-off point.... but its won't necessarily be the exact triangle shape you see below.
  • 3692399205?profile=originalThis is what I have so far.  I want to see if this will takeoff and then comeback and land then takeoff again.   Does this look right?
