Please help me with criticisms and comments since I am a NEWBIE at Drone Building.  When I built my 3DR QUAD airframe ( still waiting on mounting the radio, props and setting up the PIXHAWK ), I wanted to provide a wider stance base for my "bird DERVA" so I drilled new holes in the arms and moved the legs out on the arms as far as possible.
Since I am also in the midst of a 500 mm wooden airframe build ( http://www.dronekits.us ), I decided to use a plastic coil book binding comb to keep my antenna upright ( parallel to my DX18's transmitting antenna )
Note the solderless breadboard on the back of "WOODIE": which will help when I begin playing with the CC3D flight controller.
Attached you will find some so-so pix of my crude efforts.
Thank you !
