More heat anomaly inversion motor rotor
Hello, my current project with a very hard to solve the problem, I tell you simple description. Eight rotor unmanned aerial vehicle (uav), the reverse motor calorific value is bigger, changing position or reverse motor is larger. APM carry four rotor unmanned aerial vehicle (uav) is above the inversion 1-2 motor heating is big, can you help me to solve? Thanks for your reply.
  • Unmanned aerial vehicle (uav) configuration problems is not very big 6025 motor 50 a electrically controlled 1855 propeller
    Put reverse motor is turn on is normal.. However, or electric heating.
    Four unmanned aerial vehicle (uav) in large load using this failure due to do So don't allow the failure.
    My 600 four big rotor motor is also the failure 1-2 fever is a 30, 3508 motor electrically controlled 1360 OARS
