Hi, thanks for clicking!
I scratch built an Arducopter based build, and I ran into a problem. Signal outputs 1-3 work just fine, but signal output 4 doesn't cause the motor to spin. I tried switching around the pins, and whichever ESC is connected to Output Pin 4 is the one that doesn't spin, even at max throttle. All others do.
ESC : Hobbysky 30A SimonK
Motor : Sunnysky Angel 2212 980Kv
UBEC : Hobbywing 3A @ 5V
Battery : Hiayin 5000 mAh 3S1P 35-45C
Only ESC signal wire attached to APM, Red and Black removed from header and tied using insulation tape.
I don't have a background, no. What do you recommend I do?
