I have a smaller 850kv motor (probably like a 2215 not sure if that size is spot on), that had its wire get cut, I had previously soldered a bullet connector to it and to the esc, it got cut again and the length of the wire is decreasing. I am debating either soldering a wire to the wire, (not sure how well this will work) or trying to take apart the motor and solder a new wire to where the current one connects. Advice?
Thanks in advance.
Matt
Tags: broken, cut, motor, wire
