I'm trying to get my motors to arm but they won't, I am running a Joystic (No Radio) and althouh the joystick is enabled and I can see the outputs moving I can't seem to get it to arm..
I have noticed that the travel does not (in the planner) go full span, also I don't have a GPS yet (still to arrive)
Anyone know what is going on?
Tags:
Did you check the Troubleshooting Guide?
Permalink Reply by Elliot on September 8, 2012 at 4:30pm I did, but it says that the RED LED will flash until it has GPS lock but what if you don't have a GPS connected?
I've never tried running with no RC at all. If I were you I'd wait until you have the full setup with RC and GPS before trying joystick mode.
Permalink Reply by Elliot on September 8, 2012 at 5:21pm
Permalink Reply by Elliot on September 9, 2012 at 2:14pm Ok, so I got a Spektrum 6 channel reciever which I binded and connected up to the ardu board.
I can see the movements on the Setup Radio bit but still I'm not able to arm the motors :(
Can anyone try doing this for me without a GPS connected to see if that is the problem? I was hoping to do a test flight without having to wait for it to arrive.
Can you verify you've already checked all the things in the Troubleshooting Guide I linked to above? (Mode 2 RC, Stabilize mode, etc).
58 members
1355 members
207 members
52 members
Powered by
