0 mounting APM 2.0 - are the rubber stands enough ? Posted by Andre K. on February 7, 2012 at 1:36pm Hi, I am having trouble with some strange wobbling on roll axis now and then.Can it be too much vibration on the APM ? - should I mount it "better" ? You need to be a member of diydrones to add comments! Join diydrones Email me when people reply – Follow
removed rubber dampers and installed the APM using 2 layers of velcro - problem almost solved.
these are the default motors with 3DR frame, are they more faulty than average ?
I already replaced al ESC's and sometimes, pitch axis does the same, but less than roll axis.
Any idea how I can test a motor to find bad connection, when it seems to work fine 90% of the time, and starts & idles fine ?
Maybe it's a failing motor in that axis?
Jason
