MPX Easy Glider Pro Modification to Pusher for FPV and UAV Platform
I loved the way the Easy Glider Pro flew but it had a Problem from the FPV Point of View it had a front Mounted Prop which was causing disturbances in the camera hence had 2 options
1) Convert to twin Motor
2) convert to pusher .
Decided to go for the later after it had a horrific crash from around 60 ft directly into the ground nose first at full throttle . The Best part of MPX is you can build the plane back even after such crashes .
SPECS: Wingspan: 71" (180.3cm)
Length: 43.7" (112.3cm)
Flying Weight: 28.5oz (810g) with standard power system
Took two aluminum angles and drove them into the fuse just behind the wing at an angle such that the thrust line of the motor would be 1/2" to 1" above the CG point of the glider ( this is very critical ).
Since I have sufficient nose weight by way of FPV/UAV equipment the extra weight behind the CG should be OK.
Here are some photo's .
She glides beautifully with a RCFORALL 2217/1500 KV Motor .
Here is a Video :
[url]http://www.youtube.com/watch?v=_KJ9OmfDVI0[/url]
Sai
Tags: Easy, Glider, MPX, Mod, Pro, Pusher, to
Hi Sai, thats good work , keep it up. I have seen this mod with your post else were. Where did you get your easy glider from? Happy new year. BTW are you RCFORALL ?
Morli
I am Venkat the Son of Sai of RCFORALL , my dad got me the EZG Pro ,my mobile no. 09381437642 .
BTW where are you from
very cool mod Sai!!!
very impressing from a boy in your age!!!!
keep it up
