For a bit of background: I've got a Mugin aircraft (http://www.troybuiltmodels.com/items/TBMUAV4-3-H.html) that I'm working on getting up and flying with an APM 2.6. I've currently got my Mugin (nicknamed Muggle) made up in plane maker for some xplane 10 simulation. I've setup my futaba T8FG super remote with my 2.6 and it arms correctly and went through the arduplane wizard without a problem. However when I then upload the HIL firmware to get setup on my simulation I'm having some problems. It loads the firmware just fine and I can connect (currently over usb but I tried via the radios as well with the same problem) and it just gets hung up with initializing. I know that it is partly working because GPS values are being received by MP in the simulation tab and are correct for where I'm loading the aircraft in XPlane. The xplane and MP pics are screenshots at the exact same instance.
Hi Calvin,
Would you be able to share your Mugin plane maker files as I'm looking also to do some simulator practice with XPlane-10 ?
Best Regards
John
