Hi all,
I newly developed a fixed wing drone with Bixler 1.1 from hk.
Below picture is autopilot cockpit module I designed for pixhawk.
I had to extend front section of the cockpit from its original length to fit longer pixhawk into the cockpit.
Also note the GPS mount and pitot tube mount.
You can see the difference between the original cockpit and 3d printed cockpit.
When finished, all the components are nicely attached to the cockpit as shown below.
Most of the components are mounted inside the cockpit and I hope this may help reducing the drag if mounted externally.
Hope I can report some good news later.
Thanks,
Kyu
Nice build. Have you seen the Pixracer? It is much more smaller than the Pixhawk 1 and has better sensors.
Thanks for your comment.
Unfortunately, I don't have pixracer now but will look at it.
