Hi folks,
I've been flying heli's for several years, but thought I'd see what these "planks" are like, so I bought an EasyStar.
Having finally built the thing; checked it's CoG, and got the radio set-up, I took it to the field. I'd say the breeze was fairly steady, and only about 5mph, so I threw it into the air on full throttle.
Boy, what a handful! Are these things normally so uncontrollable? It was all over the place!
Needless to say, it's now about 5mm shorter than when it took off, but it survived :-)
I tried several times more, but with similar flight style - what am I missing? (Cue the humour!)
Cheers,
Simon
Hi!
Well, like our helis, how's the trim? Does it glide level? Do your control rates need taming a bit?
Have you upgraded it to a brushless? That and running Ardupilot on Stabilize will help a lot. You're looking for too things in wind - power to spare and weight as ballast. I fly in 10 mph winds without worrying too much.
Jason
Thanks for the replies folks.
@John: Being my first foray into planes, I believe I've set it up as per the instructions - GoG as required and all surfaces straight & true. As for "does it glide level" - dunno, it's never glided; just climbed / descended / generally been a handful! It could be the loose nut on the sticks, but I'd hoped my years with heli's would've tamed that LOL.
@Jason: I've not upgraded to brushless yet, and haven't put any AP in yet either - I was hoping to build it and prove it as a "stock flyer" before entrusting it with any more hard-earned cash! I guess some extra weight should help - I'll give that a try when the wind dies down again (I hate living in the UK!).
After checking trim and CG, make sure your prop isn't on backwards. It makes a huge difference. Since it's a pusher and not a puller it can be a little non-intuitive which way the prop goes. It'll never get enough airspeed up to be stable so you might be constantly on the verge of a stall. Just a thought.
Brian
San Francisco has brutal winds that keep me on the ground most of the summer. Two months ago I ripped both of the wings clean off of my EZstar while flying on the cliffs along the coast. I even fly with a 3 foot carbon wing spar specifically to keep that from happening. I'm thinking a 25-30 mph gust hit me at just the right moment.
I tend to put up with the trek down to Baylands or Rancho, though the wind's been pretty good at Roosevelt for the last few times I've been out there.
Is there anywhere you go to fly/test APM regularly? I'm working through my first install in a TSII and would really enjoy seeing the system in action, as well as getting myself up to speed...
You need a decent amount of weight in the nose. I have a 3S 2200Mah all the way in the nose, and it's just about right.
Does it porpoise, or is it just slow and uncontrollable? (backwards prop)
A little brushless motor is pretty nice on these. Here's a build list that I still use successfully in the air.
JC
Yes, to repeat all the advice here: you have to upgrade to brushless. The stock EasyStar motor is a joke.
The ES flies fine "as intended" with the stock setup. But what most people want from it is not "as intended". It's meant to be slow and docile, giving a beginning pilot time to make plenty of mistakes and still get out OK.
As folks have noted, it hops up well, and when hopped up, is a much more interesting and versatile airframe...
Hey, thanks for these replies guys.
@Brian: I _think_ I've got the prop the correct way round - I'll check again.
@Jason: Ouch! I've already put a longer carbon spar in the wings, as I want to add ailerons - just seems more intuitive, maybe coz of my heli background.
@John: Thanks for the xls; I'll probably follow some of that - esp. the motor & ESC.
From what I remember it was a bit of both (porpoising _and_ uncontrollable). I think I'll check the prop orientation - I'd not paid that much attention to it as I'd not realised how much difference it would make!
@Chris: Looks like I'll be upgrading then :-)
Thanks again folks.
Cheers,
Simon
Simon,
I've had two and don't like them. I converted both to brushless and added the extra rudder area. They are quite skittish, although glide ok. I always had problems at launch when they wanted to return to mother earth with great haste and never climbed out with great authority. I think the thrust line with the more powerful brushless motor causes the problems. I never got around to trying a smaller prop than the 6 x 4 I was using.
I also found that trying to setup a APilot gave very unpredictable results - one day stabilisation was ok the next it was all over the place. My high wing trainer that I am now using is much more consistent.
Both mine eventually tucked under and went into an unrecoverable vertical dive.
Good lcuk, Peter
Well, it's time for me to blush - it turns out that my CoG was forward by about 3cm! I'm sure I checked it at least twice upon build completion, so I really can't explain it, but I can confirm that it now flies OKish - high throttle tends to send it earthwards, and no throttle tends to induce stall, so I guess I need to play with CoG a little more, but at least I can now do reasonably controlled circuits, and land without crashing :-)
Thanks for all your replies folks.
