Naze32 Self Level Mode?
Hello everyone,
I'm looking to get the Naze32 Acro Rev6 Flight Controller for my MHQ2 that I'm going to build. I was just wondering if it's possible to switch it back and forth between self-level mode and acro mode, and if so, how.
Thanks.
This is the link to the exact Naze32 that I'm going to order.
  • Thanks so much! I'll take a look at the playlist.
    John R said:
    You may want to look at documentation for CleanFlight or BetaFlight firmware which is what you will want to run on your Naze32 board.
    You certainly can switch between Acro/Level mode (it's called Angle Mode in CF/BF) using a switch on the transmitter.
    Check out this great playlist on the Naze32 board:
    https://www.youtube.com/watch?v=4OKGMhTrqOU&list=PLYsWjANuAm4p4...
  • You may want to look at documentation for CleanFlight or BetaFlight firmware which is what you will want to run on your Naze32 board.
