Hi guys!
I am wondering if I should solder my Motor to ESC and ESC to Power Distribution Board...
of course I've cut the nasty bullet connectors from motors and I have some nice replacement ones (the same as turnigy batteries...) but of course they are too big to fit in the arms holes... so
shoulf I solder these connectors on PDB and on a cable in the arms and on the motors (making this a 4 connector per motor or just not bother with it and solder it all together, no connectors? or only 2 at motor and solder the ESC to PDB?
see I dont mind any as I dont know if we often remove motors/ESC from PDB... I guess it's only on crash to change parts... so cutting the wires is not really an issue... is there other reasons to have connectors?
I tend to get overkill so mayby my 4 connector per motor to  ESC to PDB is too much...
let me know! :)
Tags: ESC, Motor, PDB, mounting
personal preference....
i would solder PDB -- ESC and have some good bullet connectors for ESC -- motor
Yeah, so no real need to quickly remove ESC...
that's what I taught...
will just do connectors at the motor then...
Tx!
I agree with Sebastian.
I tried the other way for upgrade flexibility (using Deans connectors soldered to the PDB and ESC's) but Ive had several motor cutouts. Basically, I would do a maneuver and a deans connector would loosen ever so slightly as to cut the power to one of my ESC's. Upon crashing, the deans connector would reconnect and I would hear the ESC rearming the motor.Im pretty sure this is the cause b/c its not always the same motor.Now Im in the process of changing - either soldering directly to the board or using bannana connectors like the EC3 or similair.
