I recently received my Turnigy 9x and 2.4Ghz amplifier in the mail. I want to be able to have my amplifier and transmitter run off of the same battery, but I'm not sure if this will be possible due to the amount of juice I will be pulling. I was thinking about using a 2500mah 3s lipo with a 3c discharge. I will also be using a five volt regulator for the amplifier. How much run time do you think this setup will last? Any comments are helpful and that you all.
  • I found this on the specs sheet, could not find data sheet at the moment. It is the model distributed by Diy Drones.
    Output Power: 1000mW. Operating Voltage: 6V @ 200mA Includes: Amplifier Unit, adapter SMA cable, Antenna and wall adapter for US.
  • do you have a datasheet from the booster you are using?
